Activity › Forums › Apple Final Cut Pro Legacy › Odd scopes/CC behaviour?
  • Odd scopes/CC behaviour?
    Posted by Jason Porthouse on October 17, 2007 at 10:35 am
    Hi All,
    FCS2 running in an G5 2ghz DP, latest OS/QT and all updates. PAL land. Running fine, but I’ve noticed some odd behaviour whilst cutting a native HDV project.
    When CCing footage (nothing heavy, just colour balance and bringing down the luminance if it’s overcooked) as soon as I move the whites slider more than 2 clicks, my histogram goes almost flat… from having a well-represented image (with admittedly blown-out highlights it suddenly goes almost completely flat. The picture changes as one would expect, i.e. subtly. The CCd clip also becomes unrendered – red bar as opposed to the green I’d normally expect. Is this a bug, or am I being a numpty?
    Jason
    _________________________________
    Before you criticise a man, walk a mile in his shoes.
    Then when you do criticise him, you’ll be a mile away. And have his shoes.
    *the artist formally known as Jaymags*
    Jason Porthouse replied 18 years, 11 months ago 1 Member · 1 Reply
  • Jason Porthouse
    October 18, 2007 at 9:31 am
    OK update time… just figured that the CC effect only goes red (unrendered) whilst the scopes are open. Odd behaviour considering they’re supposed to be realtime scopes…close the scopes window and presto! green bar again.
    Another feature, I guess!
    Jason
