Activity › Forums › Adobe After Effects › Odd glitch with stills when using Ray Trace engine
  • Odd glitch with stills when using Ray Trace engine
    Posted by Glen Jennings on May 5, 2017 at 8:30 pm
    Hi I’ve got a comp using the ray trace 3d engine for the purpose of extruded text. I have an odd reoccurring glitch that I can’t seem to fix with some layers that are sill images precomped. I’ve swapped out jpgs for pngs and tried cleaning out the memory cache but this glitch remains in my previews and renders.
    The glitch is like the stills seem to flutter into dithered dots to total white and back like a bad tv signal. See screen cap.
    Anyone have suggestions?
    If you can’t tell a tale tall then it’s not a tale at all.
    Walter Soyka replied 9 years, 4 months ago 2 Members · 1 Reply
  • Walter Soyka
    May 5, 2017 at 9:08 pm
    Are those layers at the same depth as some other layer? Try moving them a pixel or two closer to the camera.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
