Activity Forums Apple Final Cut Pro Legacy odd flashframes
  • odd flashframes
    Posted by Pamela Magnus on February 9, 2011 at 7:08 pm
    I’m cutting a promo out of a PAL tv show and the files I were given were H.264 quicktimes. They cut no problem but any time I try to add any effects, even something as simple as a cross dissolve, or subtitles even, I get flashframes. I’m guessing this has something to do with the way the original files were compressed but is there anything I can do about it?
    Richard Cooper replied 15 years, 7 months ago 3 Members · 2 Replies
  • Chris Tompkins
    February 9, 2011 at 8:26 pm
    Please, you should NOT edit h264 files in FCP.
    Convert files b/4 editing.
    Chris Tompkins
    Video Atlanta LLC
  • Richard Cooper
    February 9, 2011 at 9:12 pm
    Hi Pamela, Chris is correct, cutting in h264s what is causing it. I tried this (only once to save a little time) and got the exact same result. Never again!
    Trans code your h264 file to a ProRes 422, edit with this file and your flash frame issue will go away.
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
