Activity Forums Adobe After Effects Odd Displacement Map Result
  • Odd Displacement Map Result
    Posted by Jordan Montreuil on October 17, 2008 at 9:18 pm
    I am using Particular that shoots out random red or green particles and am trying to use that particle layer as a displacement map set to red and green for displacement channels. I thought this would give me a heat displacement effect but its just moving the entire frame, not scrambling the areas where the particles are.
    I am confused. Can anyone give me a hand?
    Jordan Montreuil replied 17 years, 6 months ago 2 Members · 4 Replies
  • Kevin Camp
    October 17, 2008 at 11:08 pm
    did you precomp the particle system (layer>pre-compose, choose to move all attributes)?
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jordan Montreuil
    October 18, 2008 at 12:22 am
    I did. I even tried precomping it with the light I am using as an emitter and the null object that I have parented the light to. The moment it precomps, it goes blank. The particles disappear.
  • Kevin Camp
    October 18, 2008 at 12:47 am
    if you open the particle precomp, are there any particles?
    did you use a custom particle? and wwas that also included in the precomp?
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jordan Montreuil
    October 18, 2008 at 2:29 am
    I figured it out. I had forgotten to duplicate the camera also for the precomp. Thanks for your help anyways.
