Activity Forums VEGAS Pro Odd audio playback problem in Vegas Pro 15
  • Odd audio playback problem in Vegas Pro 15
    Posted by Alex Regnell on September 7, 2018 at 4:10 am
    Hi everyone,
    Lately I’ve been having issues playing back recordings done in NVidia’s Shadowplay software while using Vegas Pro 15. The audio peaks build oddly in Vegas Pro, and at times, cut out – even when there are peaks visible. I tried putting the same clip into Premiere Pro and the audio plays back much better. After this, I realized today that the audio at the same point in time that was played back in Premiere Pro, now plays back in Vegas.
    https://www.youtube.com/watch?v=403bpRyccHU
    Hopefully this link is okay – it’s a demonstration of the issue that I’m having. I’m on a fresh install of windows, all of my drivers are up to date, Windows is on the latest version.
    My PC specs are:
    i7 6800k
    32GB Ram
    The video was recorded to and accessed from an SSD.
    GTX 1080 Ti
    I really enjoy the Vegas Pro platform but I might have to switch to Premiere as my primary if these issues persist.
    Thank you for reading this.
    Alex Regnell replied 7 years, 11 months ago 1 Member · 1 Reply
  • Alex Regnell
    September 7, 2018 at 5:54 pm
    Just wanted to let everyone who is reading this know that I believe I found a solution. You have to access the internal preferences with Shift + Click on the Preferences, Internal, then look for an option called So4. I had to change “Enable So4 Compound Reader for AVC/M2TS” from TRUE to FALSE and this seemed to remake all of the peaks and play audio back correctly.
