Activity › Forums › Adobe Premiere Pro › OCR on BITC?
  • OCR on BITC?
    Posted by Josh Orr on January 13, 2015 at 12:15 pm
    Hi all,
    Apologies if this is in the wrong forum, this is my first post and I’m trying to find a solution to a problem I have. I just have Premiere in our office hence posting it here but we’re open to getting other software if needed.
    I work for a transcription company and regularly get sent videos to transcribe and timecode with a BITC. We use software that automatically inserts the timecodes and offsets them against the video position to match the BITC, but sometimes we get videos that are several clips stitched together, so the BITC (and therefore our offset) jumps around.
    It’s not a problem to change the timecode offset to counter this, the problem comes in finding where exactly the timecode jumps – it’s either a process of manually scanning the video, which takes time, or letting our transcribers do it, who aren’t that technical and can make mistakes. So I was wondering if there’s any way to use some kind of OCR to scan the BITC on the video for me and find where it changes?
    Again, the solution doesn’t necessarily need to be Premiere-based, but if anyone knows of a way to do this that would be massively appreciated.
    Josh
    Tero Ahlfors replied 11 years, 8 months ago 3 Members · 3 Replies
  • Joe Barta iv
    January 13, 2015 at 2:51 pm
    I don’t know if Premiere’s Scene Detection would work for your situation, but it may be a start.
    https://helpx.adobe.com/premiere-pro/using/capturing-digitizing.html
    Scroll down to the Scene Detection section.
    Joe
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
  • Josh Orr
    January 13, 2015 at 3:16 pm
    Hi Joe,
    Thanks for getting back to me – that looks like the sort of thing I’m after, but it looks like that only works when you’re capturing from DV/HDV – we almost always get MP4 or MOV files to work from so not sure how I’d feed those in. Will look for something similar though!
    Josh
  • Tero Ahlfors
    January 13, 2015 at 4:31 pm
    You can scene detect in Resolve and export an XML out to Premiere.
