Activity › Forums › Adobe Premiere Pro › obtain high uality images from .MTS video file
  • obtain high uality images from .MTS video file
    Posted by Gabriella Scata on September 5, 2016 at 5:32 pm
    Hi all!
    I need to obtain a high quality image (300dpi) from a .MTS video file.
    I’m trying to use VLC media player and I read i should deinterlace with Bob or Yadif2x and then take a snapshop (i usually pause the video and ake the snapshot) and then i convert the snapshot picture into a 300dpi image with Irfanwie…
    any better way to obtain better results? the image still loos blurry and low quality even when i select frames with the least motion…
    I would appreciate any help! im quite new in this field!
    Thanks a lot!
    Gabry
    Craig Howard replied 10 years ago 5 Members · 4 Replies
  • Tero Ahlfors
    September 5, 2016 at 5:47 pm
    You will only get as big a resolution image it was captured in. For example if the video was shot in 1920×1080 that is the resolution you will have. There’s no dpi in video.
  • Chris Wright
    September 5, 2016 at 6:04 pm
    It may be interlaced but same full frame motion. also, super resolution has a plugin that compares adjacent frames to get a larger sampling of data of much higher quality resizing.
  • Robert Withers
    September 6, 2016 at 2:58 pm
    I’ve used Adobe Media Encoder to convert .mts files to prores for movie editing. No experience with AME and stills though.
    Robert Withers
    Independent/personal/avant-garde cinema, New York City
  • Craig Howard
    September 8, 2016 at 9:55 pm
    If you have PPPro…use the Camera Icon in the Source Monitor or Program Monitor to Export a “frame grab”
    Source Monitor exports a frame grab as per source file.
    Program Monitor exports a file as per timeline – ie with FX etc…
    PNGs are best file types.
    You can enhance these files a little in PhotoSHop. eg sharpening (recommended), grading etc…but they still only have a rez of the original movie “capture” eg 1080p, 720p, 2K, 4K etc…
