Activity › Forums › Maxon Cinema 4D › Objects won’t fall
  • Objects won’t fall
    Posted by Kory Kearney on July 18, 2013 at 4:39 am
    I’ve been trying to put a sphere in the air and have it fall and hit a box, but everytime I try doesn’t work. I put the similation tag as rigid body and it still doesn’t do a thing. What should I do?
    Brian Jones replied 13 years, 2 months ago 3 Members · 10 Replies
  • 10 Replies
  • Brian Jones
    July 18, 2013 at 3:16 pm
    what version of C4D?
  • Kory Kearney
    July 18, 2013 at 5:35 pm
    R14
  • Brian Jones
    July 18, 2013 at 6:28 pm
    this is what’s required as a minimum set up. No settings are changed in the dynamics tags which is ok since the shapes are just a sphere and a box.
    6278_dynamicsminimum.c4d.zip
  • Kory Kearney
    July 18, 2013 at 7:35 pm
    So what do I do with that?
  • Brian Jones
    July 18, 2013 at 8:11 pm
    the link is an example file in C4D 14 format
  • Kory Kearney
    July 18, 2013 at 8:21 pm
    Yeah that’s the problem I’m having
  • Kory Kearney
    July 18, 2013 at 11:57 pm
    how do i fix this so my object will fall? I really need to know.
  • Lance Moody
    July 19, 2013 at 4:43 am
    You are pressing play on the timeline, right?
  • Kory Kearney
    July 19, 2013 at 3:03 pm
    Yes
  • Brian Jones
    July 19, 2013 at 3:13 pm
    post the scene file where it’s not working then since it should work, can’t tell what your problem might be since it’s usually not a problem. Did the example file I sent work? (it works here)
