Activity › Forums › Adobe After Effects Expressions › Objects rotation dictates precomp’s rendered frame?
  • Objects rotation dictates precomp’s rendered frame?
    Posted by Ryan Hauser on July 27, 2016 at 7:10 pm
    I feel like this is going to be really hard to describe.
    Comp A has a 2 second looping animation of a rectangular prism rotating towards the camera.
    Comb B has a rectangle with a Precomp of Comp A parented over it.
    I want the rotation of the rectangle to dictate what frame of Comp A for Precomp A to render at any given time.
    For instance, if the rectangle has a rotation of 0, it will render Precomp A from frame 0 of comp A. If the rectangle is rotated at 180 degrees, it would render the precomp to appear as it does in Comp A at frame 30. Am I making sense? I feel like I’m not making sense. Here’s a picture I drew in 5 minutes.
    Either way, if you can decipher what I’m trying to get across, I’d love to hear your thoughts!
    Ryan Hauser replied 10 years, 2 months ago 2 Members · 5 Replies
  • Dan Ebberts
    July 27, 2016 at 7:49 pm
    I would think a time remapping expression like this would do it:
    degPerFrame = 6;
    r = thisComp.layer(“rectangle”).transform.rotation;
    frame = r/degPerFrame;
    framesToTime(frame)
    Dan
  • Ryan Hauser
    July 28, 2016 at 3:47 pm
    Awesome, that’s works exactly as I wanted it to! However, I do have a few questions.
    Comp A is only 2 seconds long, making a single full rotation. This means the rectangle in Comp B can only make one full rotation of 360 degrees before the fake 3D stops working. Same thing with rotating counterclockwise; once it goes into negative rotation it will render Precomp A as it appears on frame 0 of Comp A. I suppose I could make Comp A longer and fiddle the expressions a little bit, but I feel like theres probably a way to get it to work indefinitely in its current state, regardless of how many times it has done a full rotation.
    Thanks for all your help so far though, it looks amazing.
  • Ryan Hauser
    July 28, 2016 at 4:21 pm
    (Here’s what it looks like now)
  • Dan Ebberts
    July 28, 2016 at 4:54 pm
    Try changing this line:
    to this:
    frame = (r/degPerFrame)%60;
    Dan
  • Ryan Hauser
    July 28, 2016 at 4:58 pm
    Perfect. Works flawlessly! Now if only I knew what any of these things meant rather than simply copy-pasting them, I’d be on fire!
    Thanks again for the help.
