Activity › Forums › Adobe After Effects › Objects flicker as camera flies by
  • Objects flicker as camera flies by
    Posted by Sara Winkle on June 8, 2010 at 10:30 pm
    Hi!
    I Keep running into a strange issue animating cameras in After Effects.
    I have my layers layed out in space and do a simple animation with the camera flying
    through space passing the layers to the right and left. I am getting a strange “flicker effect” on the objects/images as the camera passes.
    I have tried the de interlacing flicker filter, tried changing the speed of the camera and a slight gaussan blur on the layers since the images are very high rez. Neither one seem to make a big difference. Any ideas? Maybe my camera settings?
    Thank you so much for your input on this!
    Tudor “ted” jelescu replied 16 years, 3 months ago 2 Members · 3 Replies
  • Tudor “ted” jelescu
    June 9, 2010 at 7:59 am
    Are you getting the flicker in a preview or a final render?
    Interlaced or progressive project? Preview on the computer monitor or external monitor (NTSC, PAL, SD/HD…).
    Are you using motion blur?
    Answer these so we can help.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • Sara Winkle
    June 9, 2010 at 5:25 pm
    I apologize for my bad English- I am from the other side of the ocean :0)
    I will try to describe this better:
    I am working in a NTSC D1 project. The Graphics are being imported into the avid.
    The flicker/ghosting effect is visible in preview in After Effects, after rendering and after importing into the avid.
    The “flicker” can also be described as a “ghosting” effect around the edges of high contrast text as well as the edges of layers I am passing close with the camera. (contrast between layers and Background or text and background)
    The ghosting around the edges of the layers is more visible close to the camera and lessens as they disappear into the distance.
    The ghosting is most extreme in detailed high contrast areas on the layers (I am passing product boxes that have detailed information on them in saturated colors)
    I have been previewing and rendering with and without motion blur,I have been turning down the contrast and tried a slight gaussen blur, none of this seemed to make a big difference.
    I hope this helps? Let me know if you need more info.
    thank you so much
    -sara
    June 9, 2010 at 6:57 pm
    All that Dave said, plus if you’re working interlaced, make sure the order of the fields is what it should be ( upper first if I remember right for NTSC D1). If all this does not help, post a short clip so that we can see what’s happening with our own eyes.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
