Activity Forums Maxon Cinema 4D Objects constantly moving upon render or Go to Start
  • Objects constantly moving upon render or Go to Start
    Posted by Sam Wag on August 31, 2018 at 12:57 pm
    Hey there,
    I’m doing some simple animation and keep running into a weird issue.
    I’ll animate for quite a bit, be able to watch it just fine, and then when I click “go to start” to jump to the beginning of the animation, many of my objects jump to new positions. They all still move as key framed, but now they’re very off relative to each other.
    This also happens when rendering. I’ve attached a screenshot showing what I see as I animate, and what it all ultimately snaps to.
    It may be related to parenting as these objects are constraint-parented to each other (the chair to the figure, the jaw to a bone in the figure).
    Once this happens, I can re-position the trouble objects and then it will render fine.. until they get set off again, by either going to the beginning of the timeline or other mystery triggers.
    So I’ll watch my animation all the way through just find in C4D and then when I render his jaw is about a foot away from him but doing everything else normally..
    Any help would be greatly appreciated!!
    The render on the right shows how the objects are re-positioning themselves.
    Brian Jones replied 8 years ago 2 Members · 1 Reply
  • Brian Jones
    August 31, 2018 at 6:24 pm
    Steve (or others) will know better probably but I’d wonder if skeleton should be a child of the chair
