Activity › Forums › Adobe After Effects › objects around rotating globe
  • objects around rotating globe
    Posted by Betty Boop2 on May 27, 2006 at 2:58 pm
    So I have a rotating earth animation. I also have individual layers of soda bottles. What I’d like to do rotate the bottles around the earth. They don’t really have to go all the way around..they need to start on the left side, rotate around while getting bigger and then getting slightly smaller they rotate around the right.
    Any ideas using AE 7.0 they might help me out. 3D is not an option for me at this time. Tnanks in advance.
    Jay Thompson
    Thompson Visual Design & Storytelling
    7 Marjean Ct.
    Kirkwood, MO 63122
    Betty Boop2 replied 20 years, 4 months ago 4 Members · 4 Replies
  • Fabiano Peres
    May 27, 2006 at 5:44 pm
    Well, I think the most usefull in this case is the 3D, but you don’t want it…
    So you will have to animate the positon and scale to simulate a rotation,
    But tell me why not to use 3D if it’s the easiest way to to it????
    Just make your bottles always look at the camera and rotate them in the top view, it will surely work…
  • Mike Clasby
    May 27, 2006 at 6:06 pm
    See this earlier post, read the whole thing, many suggestions):
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=877043
    And a standard way is to make the layers 3D (check the cube), positon the layer in the initial position, parent them to a null (rotateed in the correct plane), then rotate the null, for a perfect rotation.
  • Aharon Rabinowitz
    May 28, 2006 at 5:51 am
    You might also want to set the individual objects to be oriented towardss the camera so they always stay head-on (Helps keep the illusion of 3D)
    Layer > Transform > Orient > Orient to camera
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Betty Boop2
    May 29, 2006 at 3:56 pm
    Thanks for help guys!
    Jay Thompson
    7 Marjean Ct.
    Kirkwood, MO 63122
