Activity › Forums › Adobe After Effects › Object removal / mocha / need advice
Posted by Glen Perez on September 5, 2016 at 10:51 pmHello! i need to do a removal operation in this shot. I need this guy to get into a portal and dissapear. But im quite lost to where to start. Can you please orient me on how to achieve this? thanks!
Roei Tzoref replied 10 years ago 2 Members · 2 Replies -
Roei Tzoref
September 5, 2016 at 11:56 pmthere are a several ways to achieve what you want but it’s not going to be that easy. you need to have this shot without your guy and cleaning it requires tracking the footage, cleaning the guy from it, and attaching it back as a clean background. since your camera is moving and you have perspective in your shot, it’s going to complicate things even more. now when you have a guy on the background on one layer, and the background clean on another – you can decide how exactly do you make him disappear which is relatively easy.
there attempts to pull this off come to mind:
1. you can try Mocha Remove module to remove the guy:
https://vimeo.com/104991815
https://vimeo.com/1207594212. another more straightforward approach would be taking a few frame from the footage with the guy in it, cleaning it very carefully in photoshop, and returning it to Ae and attaching the clean background to the footage via 2D tracking. you would have to track different areas because you have perspective in your shot. the tree and the floor would be two of them.
3. another approach would be same as 2 for cleaning the shot, but to use camera projection to project the clean images on top of a 3D tracking data. like in this example: https://www.youtube.com/watch?v=8J1iwmjnpWo
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Roei Tzoref
September 6, 2016 at 1:13 amI forgot to mentioned another fun part here which is the rotoscoping of the guy… you would probably have to cut him out of the original footage too if you want more options to this effect. so this means in it’s most simplest setup:
Layer 1 – the guy cut from the background in the transition frames
Layer 2 – the patched parts of the clean BG tracked in place
Layer 3 – the original video
