Activity › Forums › Adobe After Effects › Object Removal in Very Complex Shot
Posted by Umar Ansari on November 3, 2011 at 1:20 amHey Guys,
I need some help removing the insignia symbol in this shot. The symbol is at the top right corner of the note, which the actor takes out of the envelope.
Here is the shot:
Please reply ASAP as this shot’s due in about a week!
Umar Ansari replied 14 years, 10 months ago 3 Members · 5 Replies -
Roland R. kahlenberg
November 3, 2011 at 3:00 amYou’ll likely get more replies if you posted the video within your COW post. Most folks, including myself, are not keen to download anything unnecessary.
Cheers
RoRKIntensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer -
Ben G unguren
November 3, 2011 at 4:20 amThis can be accomplished with Mocha AE (it ships with the more recent versions of AE, so you probably have it). There are a TON of tutorials online for Mocha — check out their website for some of the best ones.
Basically, you will track that icon in the corner with Mocha, then export that tracking information as corner pin information for AE to use. You will create a “patch” that will cover up the icon (in Photoshop, for instance). This patch is animated to follow the icon. From there you need to do some rotoscoping so the edges of the paper look correct, as well as removing things like fingers getting in front of it, etc.
A second option, since the back of the paper is so plain, is to do a basic AE track of the icon, then match a solid and try to make it match as best you can. The Mocha option will do a much better job, however.
Also — THIS IS KEY — your footage was shot at 24 but is playing back at 30. This means it has pulldown applied. In this case it is standard 3:2 pulldown (not “advanced 3:2 pulldown”). You need to remove this in after effects before proceeding. If you are editing at 30, you can reintroduce the pulldown when you render, but those “sliced” frames will absolutely ruin your composite otherwise. So before you do anything else, make another version of your clip without the pulldown (so it’s running at 24). Good luck!
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Umar Ansari
November 3, 2011 at 2:58 pmYes, that is my usual technique when it comes to object removal for the most part. Would you suggest that I roto every frame? Because it tracks well but the composition just looks awkward with mask edges sticking out.
Ben G unguren
November 3, 2011 at 4:05 pmYea, there are two parts to the process. One is the MOVEMENT (the corner pins), the other is the ROTO (masking). One of the awesome things about Mocha, as you know, is that it will use the data you gather for the movement and help make the roto-ing process easier! Gotta love Mocha!
Ben Unguren
Umar Ansari
November 8, 2011 at 4:22 amThanks, I got it to work without using Mocha. Simply by point-tracking in AE, then inputing and masking a clean plate. Works better than I expected and is usable.
