Activity Forums DaVinci Resolve object passing in the front
  • object passing in the front
    Posted by Cesar Mendonca on June 30, 2014 at 10:36 am
    Hi guys,
    I’m correcting a scene and a woman passes in the foreground and sweeps across my image.
    How can I create a mask that will disable all other corrections while she passes?
    cheers and thanx for the input
    cesar
    MEndonca
    Cesar Mendonca replied 11 years, 10 months ago 3 Members · 3 Replies
  • Sascha Haber
    June 30, 2014 at 12:59 pm
    The easiest is to use a second track in which you copy your clip, delete all nodes, create an alpha output and then make one node in which you draw your shape.
    That will overlay the ungraded foreground without tampering with all the rest.
    It also gives you the freedom to grade her separately and play with the blend nodes of the second track
    A slice of color…
    Resolve 10.1.4 – Smoke 2015
    Colorist / VFX / Aerial footage nerd
    https://vimeo.com/saschahaber
  • Joseph Owens
    June 30, 2014 at 5:00 pm
    [Sascha Haber] “The easiest is to use a second track in which you… &tc.”
    Or a tracked power window in the appropriate shape.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Cesar Mendonca
    July 1, 2014 at 2:44 pm
    thanx guys,
    I’ll give it atry and see how it goes.
    cheers
    MEndonca
