Activity Forums Adobe After Effects Object Not Clear
  • Object Not Clear
    Posted by Kim on June 15, 2005 at 12:31 pm
    Hi there,
    I have a problem here in AE . When I create a plain colour (white/black) bar in composition, during the movement from up to down or left to right, there is some boxes appear at the border of the bar. It looks like the original size of the object is very small and I resize it to a larger object so causes it becomes blurred.
    Unfortunately this happens not only during the movement of the bar but when it stops at a position and still, the border of the bar is again blinking with the boxes.
    Does anyone have this experience and know how to solve this problem?
    Hope could get advice from here.
    Thanks so much and appreciate if this problem can be solved.
    Cheers,
    Kim
    Kim replied 21 years, 3 months ago 2 Members · 2 Replies
  • Al
    June 15, 2005 at 1:59 pm
    ok taking a stab in the dark here as i’m not sure i quite understand the issue–
    i think the boxes in the corner you are seeing as simply indicating that you have that layer selected. they’re not actually apart of your composition, they’re just to tell you that’s the layer you’ve selected.
    when you create a new colour (i assume you’re creating a new solid) – don’t scale up the solid, rather make the solid itself bigger to begin with (CNTL SHIFT Y to change it’s size)
  • Kim
    June 15, 2005 at 2:40 pm
    Thanks a lot Muiisal for you reply.
    I think it’s quite hard to describe the exact problem that I’m facing now. The boxes that I mentioned are not the yellow box that appears when I select that layer. It appears in the MPEG file. These boxes are like something that shown not clear or blurred. They are like in a movie, when there is censored part and the boxes appear to cover that part of the screen. Do you get what I mean?
    When I create a solid bar – white or black, I create according to the size that I want without resize it to bigger one. It’s just the original size.
    Hope this will clarify and give you a clearer picture about my problem.
    Thanks a lot!!
    Kim
