Activity Forums Maxon Cinema 4D Object Grow on effect
  • Object Grow on effect
    Posted by Ryan Kehn on October 27, 2009 at 9:36 pm
    Howdy Sports Fans,
    I’d be much obliged if someone can help me out with this one. I’ve got a 3d Object of a honeycomb type pattern used in the background of a logo that I’d like to have “grow on” to fill in it’s space. Think sort of like vines growing. However, I do not have the original vector files so sweep nurbs is kind of out of the question and I’m not very familiar with animated alpha mattes in a layer shader, but might that work for what I’m after? If so, could someone point me in the right direction:)
    Any other suggestions would be greatly appreciated!
    Thanks so much!
    Best,
    Ryan
    Adam Trachtenberg replied 16 years, 10 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    October 28, 2009 at 1:03 am
    What you could do is select all the top edges (from a side view) and then convert those to splines with the Structure>Edit Spline>Edge to Spline command. Then use the splines in an extrude nurbs.
