Activity › Forums › Maxon Cinema 4D › Object dynamics not interacting properly with extruded vectorised object. Look like a box has been put around it.
  • Object dynamics not interacting properly with extruded vectorised object. Look like a box has been put around it.
    Posted by Al Michaels on February 15, 2019 at 11:27 am
    SOLVED!
    Changed the Mesh from Automatic to Static Mesh on the dynamics tab
    Hey there!
    I’m having issues making a pinball machine.
    I have take a B/W Image from Photoshop and use the vectoriser to extrude the spline into an object. This Object has holes in and when I make a cube fall onto the extruded object the cube hits an invisible surface that doesn’t let it fall through.
    I have added a collider tag to the extruded object and a rigid body to the cube. The extruded object has been made editable and I have selected all faces and align/reversed the normals. Still no help. I’m sure it something simple and just my lack of knowledge regarding modelling is letting me down!
    Any support in this would be much appreciated as I really would like to understand in greater details the workings of modelling!
    Cheers
    Al
    IMAC pro
    C4d Studio R19
    all the best
    al
    Al Michaels replied 7 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
