Activity › Forums › Maxon Cinema 4D › object buffer
  • Glenn Takakjian
    January 22, 2006 at 10:20 pm
    Is this Cinema 9.5? My Composite tag doesn’t have nearly as many options… AND I have tried it and I don’t get an Alpha Channel through the Multi Layer save… I just get the same RGB file as the regular save…
    I must be missing something
    TAK
  • Doug Bassett
    January 23, 2006 at 1:47 am
    make sure object buffer is enabled with ID 1 on your object.
    In the render settings check to see that you have object buffer selected for the multipass output.
    Also make sure to save the multipass output as a file.
  • Glenn Takakjian
    January 23, 2006 at 4:33 am
    Apparently the multi pass n eeds to be saved as a targa file. As a tiff, it just comes across as a plain ole RGB file
    Thanks. Very Helpful
    TAK
