object boundaries
I’m using AE 6.5 pro and I import a lot of photoshop files as compositions into ae.
The problem I have is that if i apply an effect to a layer, such as a “glow” effect, it stops at the outer boundaries of that object.
For example, if I have the letter “O” in a photoshop layer, when a glow effect is applied in ae, its as if there is an invisible box shaped mask surrounding the object which crops the effect immediately above,below and to the left and right.
I hope I have explained myself clearly…
Is there any way to remove this invisible mask and increase the outer limit?
