Activity Forums Maxon Cinema 4D Object and shadow with transparent background
  • Object and shadow with transparent background
    Posted by Lasse Ankanpää on August 19, 2009 at 4:13 pm
    Hi
    Im trying to make a still image of an object with a transparent background. I know how to do this, you save it with alpha channel and in photoshop you select it and extract it from the image. But i want the objects shadow that shows in the floor to also be included. So when i would extract the alpha channel it would leave the object and the shadow to the layer and make the background transparent. I know that you can make separate layers using multipass but im not sure how…
    Thanks in advance
    Adam Trachtenberg replied 17 years, 1 month ago 3 Members · 2 Replies
