Activity › Forums › Maxon Cinema 4D › .Obj export file size
  • .Obj export file size
    Posted by Gage Ullman on September 1, 2021 at 9:46 pm
    So… I have a 24 mb .c4d file, and whenever I export to .obj it becomes a 4 gb file… and I’m trying to export a 600 frame sequence. I’m not aC4D user, and honestly mostly a 2d animator. Anybody know what’s going on here?
    Jim Scott replied 5 years ago 2 Members · 3 Replies
  • Jim Scott
    September 1, 2021 at 11:29 pm
    Are you saying that the project file itself goes from 24 mb to 4 gb after you export the obj sequence? The folder containing that sequence of obj files could be 4 gb if the individual obj is sufficiently large enough, but I don’t know why the project file would increase. If that’s what’s happening, could you walk through the steps you’re taking for the export?
  • Gage Ullman
    September 1, 2021 at 11:35 pm
    No, the exported .obj file is 4gb. I’ve just heard back from Maxon, and they think it’s a problem with having to bake the instances into actual geometry, which makes sense because there’s a small section of trees with leaves. No being hugely familiar with this stuff, I wouldn’t have expected such a large increase in file size, but it makes sense to me.
  • Jim Scott
    September 1, 2021 at 11:45 pm
    OK, thanks for the follow-up.
