Activity › Forums › Sony Cameras › NXCAM recording in SD 16:9 comes out looking interlaced?
  • NXCAM recording in SD 16:9 comes out looking interlaced?
    Posted by Elise Potaka on September 2, 2011 at 10:25 am
    Hi, I’m a newbie to the forum.
    I just got a Sony NX5, and recording in HD is fine.
    But when I record in SD 720 x 576, and log and transfer into FCP 7.0.3, the footage looks like it needs to be deinterlaced or something. It has those strange lines on the edge of objects, especially when there is movement.
    I’m using Pro Res 442, and when I export via compressor to mpg 2, it’s a bit better, but still not quite right.
    My sequence settings are automatically generated when I drag the clips into the timeline.
    Does anyone have any idea how to fix this? It’s quite urgent as I have a job coming up that requires footage in SD 16:9.
    Thanks, Elise
    Don Huckleberry replied 14 years, 12 months ago 4 Members · 4 Replies
  • Uli Plank
    September 3, 2011 at 8:07 am
    Better shoot HD and scale down.
    Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
  • Elise Potaka
    September 4, 2011 at 12:01 pm
    Thanks Uli, thanks…that’s what I think I will do.
    But just wondering in the longterm how to solve this – I don’t think a camera like this should have that kind of problem. So wanted to see if anyone else had that problem. cheers, Elise
  • John Lenihan
    September 4, 2011 at 2:40 pm
    I have shot a lot of SD video in 740 x 480 60i 16×9 aspect ratio.
    When I bring it into Sony Vegas, I do not have the symptoms you describe. For me, it works fine.
    John Lenihan
    John Lenihan
    LeniCam Video Productions
    https://www.lenicamvideoproductions.com
  • Don Huckleberry
    October 5, 2011 at 3:40 am
    Hi Elise,
    I am assuming you are shooting PAL given the SD resolution you listed. If you are in the US and should be shooting NTSC, that would be the first issue. I am not familiar with the camcorder – some allow you to switch NTSC/PAL no matter where you are located.
    If you are in Europe and PAL is correct, the the video should be interlaced as you describe (PAL does stand for Phase Alternating Line) – different software process it differently, so some automatically de-interlace for viewing playback in the software. You would not see the interlacing “combing” while playing back on an older NTSC TV/monitor.
    You may be able to shoot progressively on the camcorder, something you will have to research since I am not familiar with it. Or, if you want to still shoot SD, you can de-interlace on output.
    It really all depends on your workflow – and FCP really wasn’t ready for AVC I suppose. I do not use AVC in a FCP workflow, but if you are upsampling SD footage to ProRES 422, the scale to HD will make the interlacing worse and it’s a problem from then on. You have to get a handle on your workflow (shooting, ingest, edit, output, etc) otherwise.
    Are you outputting to web, DVD, BD?
    Hope this isn’t too late to help. Give me more info and I will try to talk you through it.
    Don
