Activity Forums Sony Cameras NX70 not properly recognized on Windows
  • NX70 not properly recognized on Windows
    Posted by Giulio Gobbetti on May 25, 2014 at 12:42 pm
    Hi all!
    I have a problem with my Sony NX70E. For quite a while I had the habit of recording on both the SD card and the internal mass storage and that worked like a charm – I had a backup of all the files on two memories and that was great. Lately, however, apparently I cannot access what is stored on the internal memory anymore.
    Whenever I connect the camera to my pc it kinda recognize it (it sees there is a new hardware connected if I go on My PC but it fails to open it if I try – I can’t see it in Manage Devices though). When I open the Content Management Utility I see the NX70E cam recognized, but it is grayed out so I cannot import the files from there.
    Now, I thought it may have been an issue with Windows 8/Windows 8.1 (I don’t remember if the issue came out with the upgrade), so I tried it on my old PC (Windows Vista): connected the camera, installed the drivers, installed Content Management Utility. However I got exactly the same problem there – camera grayed out in the CMU software and not properly recognized by the PC either.
    It is probably worth saying that the camera understands to be connected to a USB power source and it gives me the usual screen (“Mass Storage Connected – USB; do not unplug etc.”)
    Have you got any suggestions?
    Thank you so much!
    Giulio Gobbetti replied 12 years, 3 months ago 2 Members · 2 Replies
  • John Lenihan
    May 25, 2014 at 2:17 pm
    Assuming that you have a backup of the information on the internal memory, try reformatting it.
    If that doesn’t work, I would call Sony tech support.
    John
    John Lenihan
    LeniCam Video Productions
    https://www.lenicamvideoproductions.com
  • Giulio Gobbetti
    May 25, 2014 at 2:31 pm
    Thanks for the reply.
    The thing is that I have a couple of minutes of one clip that have not been saved on the SD (the card was finished and I did not want to cut in the middle of an important action just to change the SD). I thought it was OK to have it just on the internal memory – I was wrong apparently. Now, I would like to recover that somehow. If I can find any solution that does not involve formatting I would be glad.
    I mean, it’s not a matter of life and death, still I would like to have it.
    Thank you!
