Activity › Forums › Apple Final Cut Pro Legacy › Nvidia GEForce 8800 no workie with FCP !
Edo Medicks replied 17 years, 9 months ago 10 Members · 24 Replies
Bob Zelin
August 23, 2008 at 4:53 pmyou pinpointed the problem, with this –
“There are now two versions of the 8800 GT kit, one for pre-2008 Mac Pros and the other for early 2008 models, so be careful when you order”In this situation, the client says “we are getting lines in our video display”. It was an ATI. I say “better order a new graphics card”. So they send the secretary out to to the Apple store, to get “any” graphics card for a MAC Pro. And so, the situation that you have seen presented in this thread occured.
Again, excellent web research !
Bob Zelin
Bob Zelin
August 26, 2008 at 1:34 amI am sure that no one is reading this thread anymore as of 8/25/08, but for the one person that is – you should go to the AJA Kona forum and see the guy posting that his FCP system is no longer working after loading in the AJA Kona 6.0 drivers ! If you have been following this thread, you will laugh.
Bob Zelin
Edo Medicks
November 24, 2008 at 5:48 pmHi all,
I had the same problem, my gt8800 shows up as quartz extreme not supported. Super sluggish windows, sluggish scrolling etc. this started after installing the AJA board. (with default driver 5.1)
But, problem solved by updating the AJA LHe driver\utility to 6.0.1.
FCP is now very fast, loads in seconds (updated to 6.0.5).
I hope all our problems are solved (until next time…)btw, does anyone know of a way to check for such conflicts? i got no indication from os x \ aja conflict test or any other util. app.
System:
Model Name: Mac Pro
Model Identifier: MacPro3,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 3 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per processor): 12 MB
Memory: 16 GB
Bus Speed: 1.6 GHz
Display:
Chipset Model: NVIDIA GeForce 8800 GT
Type: Display
Bus: PCIe
Slot: Slot-1
PCIe Lane Width: x16
VRAM (Total): 512 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x0602
Revision ID: 0x00a2
ROM Revision: 3233
Displays:
Display Connector:
Status: No display connected
Cinema HD:
Display Type: LCD
Resolution: 1920 x 1200
Depth: 32-bit Color
Core Image: Hardware Accelerated
Main Display: Yes
Mirror: Off
Online: Yes
Quartz Extreme: Supported <<<<<<< Rotation: Supported AJA: Version 6.0.1 (6.0.1)
