Activity Forums Adobe Premiere Pro Nvidia Fx 3800 in Premiere Pro
  • Nvidia Fx 3800 in Premiere Pro
    Posted by Bob Dix on September 1, 2010 at 4:01 am
    XEON Quad Core processor 2.27 Ghz with 12 Gb ram and 1,000 Gb hard drive basically for use with High definition editing.It is equipped with a NVIDIA FX 3800 which works very well with H264 codec even with Premiere Pro 1.5.1 but, there has been a minor problem when using Photoshop when it says” Display driver Nividia Windows Kernel Mode Driver Version 191.87 Stopped responding and has fully recovered”.259.12 Quadro -Win 64 bit has been installed by Dell and seems to have solved the problem. You will need a 64 bit system if you intend upgrading to CS5 Premiere Pro..
    I too have a Dell Dimension 8400 Multi Processor 3.2Ghz Pentium with hyperthreading which does a resonable job still,but, is slow rendering. If you get hyperthreading on the Precision Workstation it could push the price up by $1,000 depending on the size of the processor.We mainly go to Pro tape HDV but, got a blu-ray burner included just in case.
    The only reason we upgraded was to more effectively use the H264 mov. files from the Canon 5D Mark II 1920 x 1080 which slowed the Dell 8400 down.The Exported High definition editing to pro tape is broadcast quality from both , the Dell Dimension 8400 as well as the Dell Precision T5500.
    Note: DISPLAY DRIVER malfunction ,any ideas , anyone???????????
    Freelance Imaging & Video
    AUSTRALIA
    Bob Dix replied 16 years ago 1 Member · 1 Reply
  • Bob Dix
    September 13, 2010 at 11:23 pm
    Problem fixed by NVIDIA patch.
    AUSTRALIA
