Activity Forums Adobe Illustrator NURBS Curves imported into Illustrator?
  • NURBS Curves imported into Illustrator?
    Posted by James Skrous on April 9, 2012 at 10:34 pm
    Hi everyone,
    I would like to know if there is a script, or software or plugin or any method where I could import Maya NURBS curves into Illustrator. I find Maya’s NURBS so easy to work with and I can do art so much faster, but obviously there’s a lot more you can do in Illustrator after the line work is done. So far the only method I could find is to use Maya’s Vector render. But this dose not follow my original line work, (it traces it) so there are a lot more points then I would like and the vector work just isn’t as clean. Also when it opens up in illustrator the art work usually acts a little weird. Its also just a lot of work sometimes to create NURBS patches, so that there is something to actually render. So any suggestions?
    Nicholas Mallinder replied 13 years, 5 months ago 2 Members · 1 Reply
  • Nicholas Mallinder
    March 30, 2013 at 8:47 am
    I would definitely like to know this as well. I’ve been using illustrator for years and have just been introduced to cv curves. Instantly got better lines.
