Activity Forums Adobe After Effects numerical adjustments of paths?
  • numerical adjustments of paths?
    Posted by Bart Stevens on April 16, 2020 at 4:26 pm
    Curious if anyone knows a technique for numerically adjusting paths?
    I know I can double click and adjust paths proportionally, but it would be nice to adjust scale numerically, or adjust points based on entering pixel values.
    Bart Stevens replied 6 years, 5 months ago 2 Members · 2 Replies
  • Walter Soyka
    April 16, 2020 at 5:46 pm
    Try the “Create nulls from path” script that’s included with Ae:
    https://helpx.adobe.com/after-effects/using/animating-shape-paths-masks.html#CreateNullsfromPathspanel
    This will give you a set of nulls that control each of the points on your path, so you easily access their position parameters, set up a parent to manipulate scale, apply expression, etc.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Bart Stevens
    April 16, 2020 at 6:28 pm
    Thanks Walter, that’s a good idea. I just recently discovered that feature… it’s very useful..
    My thoughts are more while working with Illustrator and After Effects. I know Illustrator will allow you to do this for scale and position for points and path shapes. I think I just need to emphasize a workflow where my AE and Illustrator projects synced up in composition/canvas size. That way I can create specific vector paths in Illustrator and copy over. Previously I wouldn’t have my Illustrator and AE projects the same canvas size, and I would need to adjust size in AE, (which gets difficult with multiple paths on multiple layers).
    Thanks again for the feedback….
