Activity › Forums › Adobe After Effects › Numeric toteboard effect
Posted by Dan Mirolli on April 16, 2007 at 3:22 pmTrying to have numbers climb from 0 to say 500,000,000 (all within a couple seconds). Is there a simple way to do this ? Tried the NUMBERS feature and it tops out at 30000. Tried using mutliple layers of this and cropping out the additional numbers and this kind of works.
Nate Vander plas replied 18 years, 9 months ago 5 Members · 6 Replies -
Colin Braley
April 16, 2007 at 3:29 pmcreate a text layer, and apply this expression to the source text property:
//Begin expression
countBeginTime = 0;//seconds
countEndTime = 15;//seconds
beginCount = 0;
endCount = 500000000;
linear( time, countBeginTime, countEndTime, beginCount, endCount)
//End expression~Colin Braley
Dan Mirolli
April 16, 2007 at 3:40 pmHI Colin,
Thanks for that. I have to ask another question though. Having not used expressions where is it I paste that script into.thanks
David Bogie
April 16, 2007 at 3:55 pm> Thanks for that. I have to ask another question though. Having not used expressions where is it I paste that script into.< You'll need to study expressions a wee bit. Not too difficult but very confusing the first few times. Open the manual and the online help systems, plus there is a complete section here on the cow for AE scripts and expressions, umm, I think. Just remember the RETURN key puts in a carriage return. You need to use the numerica pad ENTER key to exit expressions. bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
Nate Vander plas
April 16, 2007 at 6:50 pmTo get you started, alt-click the stopwatch of the property you want to add an expression to. Then a box will appear in the timeline. Paste your expression there.
Also, the pickwhip is a very handy tool for linking one property to another. -
Kevin Dooley
November 20, 2007 at 6:49 pmJust a couple quick questions… is there a way to have this not use decimal places and also to use punctuation (appropriate commas)?
Kevin Dooley
Senior Content Creator
Lake Pointe Church -
Nate Vander plas
November 25, 2007 at 8:30 amI’m no expressions guru, so my solution would be to just duplicate the layer (3-4 times), mask off each dup so that it only shows 3 digits, then make a little space between where the comma should be and just add commas with separate layers. I know this isn’t the ideal way, so I recommend asking Dan Ebberts in the expressions forum or by e-mail (he’s very helpful and generous). He has his own website dedicated to expressions, but I can’t remember the address. Just google it.
