Activity Forums Adobe After Effects numbers effect speed
  • numbers effect speed
    Posted by Erin Patrick on March 13, 2006 at 3:21 pm
    Can anyone tell me how to control the speed of the numbers effect? Specifically- slow it down. I’ve tried precomping and time stretching, and I can’t find any controls for it in the effect itself. I’ve also searched in the archives to no avail.
    Any help is appreciated. Thanks!
    Adolfo Rozenfeld replied 20 years, 5 months ago 4 Members · 3 Replies
  • Dan Blaim
    March 13, 2006 at 4:04 pm
    You could try to set keyframes under Value/Offset/Random Max to be closer in value. Or set keyframes further apart.
  • Brian Charles
    March 13, 2006 at 5:11 pm
    You could render the number animation with alpha and use time remapping. Try changing the frame rate of the comp.
  • Adolfo Rozenfeld
    March 14, 2006 at 6:55 am
    eriness: Pre-compose the Layer. Then apply the Posterize Time effect (Time category) to the pre-comp. If you set the effect value to 5, for example, the numbers will definitely slow-down (update 5 times per second).
    Adolfo Rozenfeld
    Buenos Aires – Argentina
    https://www.adolforozenfeld.com
    adolfo(AT)adolforozenfeld.com
