Activity › Forums › Adobe After Effects › numbers effect but with text?
  • numbers effect but with text?
    Posted by Heather Crank on September 14, 2007 at 2:25 pm
    Hello All,
    I am trying to find a VERY QUICK way to make text change/move like numbers do when I apply the text numbers effect. Any suggestions????!!!
    Thank you!
    H
    Todd Kopriva replied 19 years ago 4 Members · 7 Replies
  • 7 Replies
  • Steve Roberts
    September 14, 2007 at 2:38 pm
    Did you check the text presets gallery?
  • Heather Crank
    September 14, 2007 at 2:40 pm
    I did, there are some that animate on, but I need something that is already on and constantly changing…..is there a preset like this that I’m missing???
    Thank you!
    Heather
  • Kevin Camp
    September 14, 2007 at 2:42 pm
    this was from the help menu for examples of text animation. it shows how to use offset characters, which sounds like what you want to do…
    Create a new composition.
    Create a new text layer with the word Galaxy.
    Choose Animation > Animate Text > Character Offset.
    In the Timeline panel, set the Character Offset value to 5.
    Expand Range Selector 1.
    Click the Start stopwatch to set an initial keyframe at 0 seconds and set the value to 0%.
    Move the current-time indicator to 5 seconds and set the Start value to 100%.
    Set Character Alignment to Center.
    Preview the composition.
    hope that helps.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Heather Crank
    September 14, 2007 at 2:44 pm
    Thanks Kevin, I’ll give that a shot!
    Heather
  • Heather Crank
    September 14, 2007 at 3:15 pm
    Worked like a charm Kevin, Again.
    THANK YOU SOO MUCH!
    Heather
  • Kevin Camp
    September 14, 2007 at 3:23 pm
    reciting the help file….. pure genius
    glad it helped
    Kevin Camp
  • Todd Kopriva
    September 15, 2007 at 5:44 pm
    [moldyboot] “reciting the help file….. pure genius
    glad it helped”
    I’m glad it helped, too. 🙂
    Todd “the guy who wrote the Help document” Kopriva
    Todd Kopriva
    Adobe Systems Incorporated
    putting the ‘T’ back in ‘RTFM’
    After Effects Help on the Web
