Activity Forums Adobe After Effects Numbers counting down
  • Numbers counting down
    Posted by Mark on May 30, 2005 at 6:46 pm
    HI,
    Trying to have a count down that goes from 20.00 down to 02.00
    Been playing around with the numbers effect but it seems to default back to + numbers once it reaches 05.00.
    So my question is, is it possible to do using the numbers effect or are there other plugins which offer greater control?
    Cheers
    M
    Yoondo replied 21 years, 3 months ago 3 Members · 4 Replies
  • Andrew Kramer
    May 31, 2005 at 12:52 am
    could you use the timecode print effect or whatever then pre-compose it and then reverse it.
  • Yoondo
    May 31, 2005 at 2:17 am
    Use the text>numbers and choose the format timecode, then keyframe 00:00 to 20:00.
    Select the keyframes and time reverse keyframes (right click on one of the keyframes)
    then go ahead and set the work area from 20:00 to 02:00.
    That should do it.
  • Mark
    May 31, 2005 at 11:24 am
    MMm I’ve been trying that but it doesnt work. When reversing the keyframes it screws up the timing (it starts at 00:00:12 and ends on 00:08:00)
    Real head scratcher this one.
  • Yoondo
    June 1, 2005 at 12:31 am
    Hit control+alt+R to reverse the layer itself (layer needs to be selected).
    Then set your work area to what you need. Try that for a size.
    Good luck
