Activity › Forums › Adobe After Effects › Numbers changes between two set of exactly same linear keyframes ( copy pasted )
  • Numbers changes between two set of exactly same linear keyframes ( copy pasted )
    Posted by Kewei Du on May 25, 2017 at 4:00 pm
    Hey guys,
    I am running into this weird issue which is. I copied and pasted the keyframes from each other, and it’s linear keyframes,
    somehow, the numbers change in between of those keyframes, so there are some unwanted motions. Please Help!
    https://youtu.be/ru1dQIvKGbo
    Kewei Du replied 9 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
