Numbered Still import problem
Hi all,
I’m new to premier pro and trying to make a time-lapse film. I have over 200 stills I am trying to import as a single film. Everything I read tells me to make sure the stills are named sequentially, which I have done. Then, to select the first image in the sequence on the import menu and click ‘numbered stills’ and premier will import all the numbered stills as a single file. However, when I follow the instructions, no matter how I sequence the images, premier will only import the first image as a film. I have named my images ‘Stars100’ with the next being ‘Stars101’ and so on to ‘Stars218’. I have tried them as JPEGs and TIFFs with no dice. What the heck am I doing wrong?
Any help appreciated! Thanks!
Nathan
