Activity Forums Adobe After Effects Expressions Number of times the expression code is run in a composition?
  • Number of times the expression code is run in a composition?
    Posted by George Felix on July 8, 2017 at 4:23 am
    A very basic question
    How many times does the expression code run in a composition?
    If I have 5000 frames in a composition and I have placed the below code in a text layer, does the code run one for the life of the composition or does it run 5000 time, once on each frame.
    X = 5;
    X = X + 1;
    George
    Dan Ebberts replied 9 years, 2 months ago 2 Members · 1 Reply
  • Dan Ebberts
    July 8, 2017 at 6:28 am
    Since the result of your expression doesn’t change from frame to frame, the result may get cached–I’m not sure. But if your expression generates a new result on each frame it would have to be evaluated on each frame.
    Dan
