Number of Backups limited in Vegas 15?
Posted by Robert Maier on April 25, 2019 at 3:45 pmIs Vegas limited to just one backup file at a time? I’m facing a bad situation where the .bak is corrupt like the .veg. Would make sense to have maybe 10 backups with an adjustable duration between backups.
Graham Bernard replied 7 years, 5 months ago 4 Members · 5 Replies -
Geoff Candy
April 25, 2019 at 6:37 pmMaybe just increment your saved veg file ‘myproject1.veg’, myproject2.veg etc.
Edward Troxel
April 25, 2019 at 7:32 pmYou might try installing Excalibur which also installs the free “Auto Save” plugin. Then you can use that plugin to save as many backups as you want in whatever folder you specify.
https://www.jetdv.com/excalibur/new6.php
Robert Maier
April 25, 2019 at 8:43 pmSure, that will work, but it’s totally out of place in a professional application. This issue may be the dumbest Vegas decision ever. Looks like Ed Troxel’s suggestion with Excalibur’s auto-save is an ideal solution, and why it wasn’t built into Vegas attests to software developers’ terrible understanding of the real-world operation of their product. Leaves me dumbfounded. Though I think I remember that earlier versions of Vegas had adjustable auto-backup. I started with version 6. Maybe that’s why I’m shocked it’s gone. Or maybe it was another editing program, Premier?
Robert Maier
April 25, 2019 at 8:55 pmThank-you. This was an easy install, and it seems to be working perfectly. Why oh why doesn’t Vegas have this auto backup customization feature? I did have a 4 day old backup on a separate drive, so am using that. EXCEPT I’ve lost the last 400 or so edits about 12 hrs of editing, because the puny Vegas autosave is limited to the one that happened ten minutes ago. My project evidently had been corrupted just before the last save, so it was no good. For this reason Vegas’ autosave is pretty worthless, and a bad reflection on Magix. I’ve been using it since 6, and it showed so much promise. IF I trusted Magix to fix things like this I’d gladly do the annual paid upgrade. But this whole thing started when suddenly my project unintentionally went into expanded view mode, and would never leave it. Then the project became unstable. Really disappointed, but the core philosophy of Vegas is by far the best in the industry, its just the little things like poor autosave that drive me CRAZY!!!
Graham Bernard
April 25, 2019 at 9:15 pmEdward’s AutoSave has saved my rear-end many many times. Thanks Edward !
* Grazie
Cameras: Canon XF300 + PowerShot SX60HS Bridge
