Activity Forums Adobe After Effects Expressions Number Counter with Comma, changing comma size?
  • Number Counter with Comma, changing comma size?
    Posted by Jim Branstetter on May 13, 2017 at 6:37 pm
    Hi All,
    I am using the expression below. I can change the font, font color but it doesn’t allow me to change the size and baseline of the comma (which is huge with the font). The size changes are global, I can not select a character. Is there a way to change the comma size and baseline with a percentage? My attempts have failed.
    Thanks, Jim
    startCount = 0;
    endCount = 2000;
    countDur = 2;
    s = "" + Math.round(linear(time,0,countDur,startCount,endCount));
    if (s.length > 3){
    s.substr(0, s.length -3) + "," + s.substr(-3);
    }else{
    s
    Jim Branstetter
    RubberBulletStudio.com
    Dan Ebberts
    replied 9 years, 4 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    May 13, 2017 at 7:10 pm
    You could try using a Scale and Position Animator set to offset values want for the commas, add an expression Selector with an amount expression like this:
    txt = text.sourceText;
    if (txt[textIndex-1] == “,”) 100 else 0
    Dan
