Activity Forums Adobe After Effects Nulls, Adjustments & Solids – All Want to be Top Dog!
  • Nulls, Adjustments & Solids – All Want to be Top Dog!
    Posted by Alex Kuzelicki on August 15, 2007 at 2:46 pm
    I just have a(nother) simple question:
    When I make a new Null, an Adjustment Layer or a Solid, no matter where I am in the current Layer order it will always appear as very the top layer.
    Usually I’ll just drag it down to where I want it – no big deal… unless you have a project with over 400 layers! (Don’t ask, it’s a long story)
    Anyway, with this project, making new Nulls, Adjusts or Solids wastes a fair bit of time just dragging them to where I want them to be in the stacking order.
    My question is, then: “Is there a way to make them appear in a particular place in the layer/stacking order?”
    From memory it seems that sometimes they do, in fact, appear immediately above a selected layer but most of the time they just jump to the top of the heap. Not sure how to ‘place’ them where I want on creation.
    I know it’s only a small thing… but every minute counts (especially with 400 layer projects – oh dear).
    Thanks in advance,
    ALEX
    Alex Kuzelicki replied 18 years, 9 months ago 2 Members · 2 Replies
  • Jeff Mcbride
    August 15, 2007 at 6:23 pm
    I’ve never heard of a way to do this, but if you’re working in a 400 comp layer my suggestion would be to color code layers and use the Shy layers to hide stuff. It’s the little guy poking his head over a bar on each layer, click that for any layer you want to hide and then click the larger guy at the top of the timeline. I would also recommend Pre-Comping stuff. If you’re working in 3D you can pre-comp something, then click the sundial box to Collapse Transformations so you retain the 3D. Good luck!
    Jeff McBride
    Motion Graphic Designer/Editor
    LimeGreen
    Chicago, IL
    http://www.limegreenproductions.com
  • Alex Kuzelicki
    August 15, 2007 at 6:47 pm
    Thanks for the suggestions, Jeff.
    Have pretty much done all of them – out of necessity – as I’ve progressed through this ‘very big’ project.
    It’s a music vid and I’m trying to do a ‘finish’ in AE – as suggested by Stu Maschwitz in his DV Rebel’s Guide – to avoid any visual loss through compression.
    I do miss the speed of Final Cut though – the rendering time in AE kills me!
    It’s all a grand experiment though. I’m going to do a comparison of a final render in AE as compared to a re-render in Final Cut (of all the composited shots) and see if there really is that much of a visual difference between the two.
    I really do prefer just bringing in specific shots where needed in AE, but apparently taking them back out to Final Cut and re-rendering for a finished cut will noticeably degrade my footage. Will see.
    Would be interested to know what other people’s workflows are for maintaining optimum quality in the final output.
    Appreciated,
    ALEX
