Activity Forums Maxon Cinema 4D Null with affected by deformers ?
  • Null with affected by deformers ?
    Posted by Edward Vosper on November 9, 2016 at 11:37 am
    Hi all,
    Im working on a project where I have some nulls with external comp tags on them ready to add text in after effects. I need to stretch the model using a taper, when I use the Taper the nulls do not move there position along with the model.
    I hope thats kind of clear, if anyone has any ideas on how to get the nulls affected by the deformer please let me know.
    Thank you
    Ed
    http://www.edwardvosper.com
    Adam Trachtenberg replied 9 years, 9 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    November 9, 2016 at 4:53 pm
    Deformers only work with actual geometry. You can use Xpresso to stick them to your model, though (or a single point that won’t render). You do that using the Xpresso point node, making sure to check the “after deformers” option in the node’s properties.
