Activity › Forums › Adobe Premiere Pro › null out correct color cast revisited
  • null out correct color cast revisited
    Posted by Paul Dougherty on September 16, 2015 at 6:26 pm
    I had posed a question like this before. Is there an eyedropper tool in Premiere CC like the one in FCP (3 way color correct effect) that allows one to use an eyedropper on what should be a neutral gray or white in an image and (instantly) null out and correct for a color cast? That is to make color cast white “true white” or grey “true grey” This is how on FCP tutorial put it…
    The eyedropper tool allows you to select a specific portion of your image that best represents true white, black or gray (midtone). Final Cut Pro will then readjustment the color automatically.
    Note that this is not a “change color” effect that is only working on one shade of grey but rather treating the image as a whole, pulling a bad color cast out of all the greys/gamma etc.
    Paul
    p.s. I came across a Lynda tutorial from the wonderful Chris Meyer called “Correcting white balance issues” but it involved placing a solid layer over the clip – it’s resourceful workaround but at this late date isn’t there a better way with the three-way color corrector ?
    Paul Dougherty replied 11 years ago 2 Members · 2 Replies
  • Steve Brame
    September 16, 2015 at 8:14 pm
    The Fast Color Corrector effect has that tool.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Paul Dougherty
    September 16, 2015 at 8:49 pm
    Brilliant Steve thanks!!!
