Activity Forums Adobe After Effects Null objects red block not outline
  • Null objects red block not outline
    Posted by Roger Corbett on January 25, 2017 at 1:28 am
    I’m working on a rigging tutorial, and my null objects are solid red blocks instead of wireframe. This is obscuring the rig and making it very difficult to see what I’m up to. No doubt I’m missing the obvious, but I’d be grateful to be pointed in the rtight direction.
    Roger Corbett replied 9 years, 8 months ago 1 Member · 2 Replies
  • Roger Corbett
    January 25, 2017 at 1:56 am
    Thank’s Dave. The Nulls are being created by Duik. Basically, you select your pins within Mesh > Deform and then click the Bones button in the Duik panel and it creates an IK rig. this tutorial I’m following the above tutorial click for click, and all is as should be apart from this issue. I thought it might be a setting in the panel view options, but no…
  • Roger Corbett
    January 25, 2017 at 4:55 am
    Thank you very much David.
