Activity › Forums › AJA Video Systems › Nuke and 1080p problem?
  • Michael Sacci
    January 3, 2010 at 2:11 am
    Is there a segmented frame (psf) setting available for the video out, that is what I need to use to go out 30p in NTSCland.
  • Joel Arvidsson
    January 3, 2010 at 11:48 am
    You have
    enable monitor output (X)
    monitor output device: Aja
    monitor output mode: example Aja kona 1080i25 10bit
    In the root settings of the project you have fps but it dosent matter if i put 25 instead of 24.
    joelarvidsson@gmail.com
  • Gary Adcock
    January 3, 2010 at 12:53 pm
    [Joel Arvidsson] “Hi Nuke works with Aja LHe when aja is set to Aja kona 1080i25 10bit in nuke. But if I choose progressiv i get a weird image. My panasonic pro plasma support 1080p. Anybody had the same problem? 720p works in nuke. “
    the default 1080 Broadcast format is PsF- or progressive segmented frame (interlace),
    https://forums.creativecow.net/readpost/193/875880
    have you loaded the 1080 P settings? True P in 1080 is rare outside of of few instances, since is is dificult to watch due to the strobing,
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
