Activity › Forums › Apple Final Cut Pro › Nudging in and out points.
  • David Battistella
    January 6, 2014 at 12:40 pm
    Select the clip
    Use the “.” To nudge forward, use the “,” to nudge backward.
    David
    ______________________________
    https://www.davidbattistella.com
  • Jason Brown
    January 6, 2014 at 1:16 pm
    Doesn’t this just move the clip? I believe the question is about nudging the range selected?
  • David Battistella
    January 6, 2014 at 2:49 pm
    In that case I would select the clip. Hold the option key and drag out one frame ata time on either end.
    David
  • David Battistella
    January 6, 2014 at 3:13 pm
    Also found this great apple doc.
    https://support.apple.com/kb/PH12550
    Basically, you are either nudging (moving an entire clip) or trimming (changing the duration of a clip buy one or more frames)
    I think the OP might be asking for a Nudge/trim feature. 🙂
    David
  • David Eaks
    January 6, 2014 at 3:15 pm
    In the Timeline-
    Use up/down arrows to jump to the desired edit point, select the edge of the clip you want to trim with left/right bracket, nudge the selected edit point with period/comma.
    Is that what you’re looking for?
    I realized you must be referring to nudging the I/O point of a range selection, I was referring to nudging the ends of an actual clip.
  • Oliver Peters
    January 6, 2014 at 4:16 pm
    [James Ewart] “nudge in and out points a frame at a time in browser”
    In the browser, use the left/right arrow (cursor) keys to move forward or backward 1 frame at a time. Park on the desired frame and hit I or O again for a new in/out mark.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • James Ewart
    January 6, 2014 at 6:49 pm
    that does not work for moving in and out points in browser here.
  • James Ewart
    January 6, 2014 at 6:51 pm
    but i want to nudge one frame at a time – dragging is less accurate.
  • James Ewart
    January 6, 2014 at 6:52 pm
    don’t work for me does it for you. One frame nudge in point? Or out point?
  • James Ewart
    January 6, 2014 at 6:54 pm
    Got it thanks – shift I takes me to in point and then arrow and then hit I again. Bit boring having two steps
