Activity › Forums › Boris FX Particle Illusion › nuclear explosion
nuclear explosion
Posted by Giglu231 on November 16, 2006 at 3:36 pmHi! I am a new user.
I would like to obtain with P.Illusion a nuclear explosion.
does an emitter exist already?
Thanks in advance for every answer.
bye
Elvis Deane replied 19 years, 9 months ago 2 Members · 3 Replies -
Elvis Deane
November 16, 2006 at 7:19 pmThere are a whole bunch in the July 2004 library.
Elvis Deane!
The Apprentice Magician’s Guide to particleIllusion
Giglu231
November 16, 2006 at 8:30 pmyes
I have seen it, even if
it is not very realistic.
I try to modify it.
can you tell me something about it?Thanks
Elvis Deane
November 19, 2006 at 10:31 amThe motion of the emitters is really good in those, so if you replace the particle shape used in the smoke emitters with something that has more detail in it, you’ll probably get an explosion closer to what you want.
A few things I did to adjust the 01b nuke:
Duplicated the Smoke Plumes particle type in the left and right free emitters. I then loaded up the August 2006 library, and used the waterflow_new6 shape on those new smokes. That added a bit more detail to the smoke.I also reset the Tint Strength graph to give the explosion more intense colours.
Elvis Deane!
