Activity Forums AJA Video Systems NTSC to PAL for DVD (In Kona 2?)
  • NTSC to PAL for DVD (In Kona 2?)
    Posted by Scott Shucher on October 7, 2005 at 7:57 pm
    I have to deliver a DVD to England so it can be viewed in PAL.
    The original format out of the Kona2 will be NTSC DV, making an
    MPEG 2 in either Compressor or Bit Vice, then burn with DVDSP4.
    Is their a difference between a NTSC & PAL Mpeg2 file?
    I haven’t had to work with PAL before. Can someone help me understand the process?
    Mitchji replied 20 years, 11 months ago 4 Members · 5 Replies
  • Itamar Kool
    October 9, 2005 at 7:54 am
    Yes there is a difference between MPEG 2 NTSC and MPEG 2 PAL. I think that in DVD SP 4 you can convert from NTSC to PAL. Haven’t tried that though.
    Kool En De Anderen
    dual 1.8 gig G5/Mac OS 10.3.9/Kona 2/Hugh 800 G diskarray, fibrechannel/FCP 5.02/AE 6.5 Pro
    http://www.koolendeanderen.nl
  • Clay Walker
    October 10, 2005 at 1:47 pm
    You can try using this FCP plug in:
    https://www.nattress.com/standardsConversion.htm
    I have used it in the past for converting to PAL.
  • Mitchji
    October 11, 2005 at 5:13 pm
    Hi Scott,
    Are you sure you need a PAL DVD? All PAL DVD players will play an NTSC DVD. They output a signal with the PAL color space and NTSC resolution and frame rate. Most TV’s produced since about mid 1990 can display that signal.
    Best Wishes,
    Mitch
  • Scott Shucher
    October 11, 2005 at 10:18 pm
    No, I did not know that. That’s why these forums are so great! As are the people who post & reply on them
  • Mitchji
    October 12, 2005 at 6:22 pm
    [MitchJi] “Most TV’s produced since about mid 1990 can display that signal.”
    Should have said most PAL TV’s.
    Best Wishes,
    Mitch
