Activity › Forums › Apple Final Cut Pro Legacy › NTSC TO PAL DVD
  • NTSC TO PAL DVD
    Posted by Subspecies on August 30, 2005 at 7:11 pm
    guys,
    do u know if it’s possible to convert NTSC dv to PAL m2v using QuickTime?
    basically i have a video that was edited in NTSC and needs to be output onto a PAL DVD…and instead of sending the self contained file to a conversion house, is there any software solution for this? and i’m assuming that FCP can’t out put PAL from NTSC….
    thanks for your help…
    Matt Sandström replied 21 years ago 2 Members · 1 Reply
  • Matt Sandström
    August 30, 2005 at 7:41 pm
    fcp can for sure, just drop your ntsc footage on a pal sequence. the quality from the built in conversion isn’t great though, but a plugin like the “g standards conversion” will do the trick.
    /matt
    https://www.mattias.nu/
