Activity › Forums › Apple Final Cut Pro Legacy › NTSC + PAL footage in same project
  • NTSC + PAL footage in same project
    Posted by Rap on October 12, 2006 at 6:29 pm
    hello
    i have 2 questions
    what do i do if i have footage that is PAL (I’m working on NTSC project)
    2- i have digitized and edited footage that was shot anamorphic and now after finished editing i print t to tape i don’t get the 16:9 mask i get a stretched picture . what do i do ?
    Vince Sanchez replied 19 years, 11 months ago 2 Members · 1 Reply
  • Vince Sanchez
    October 12, 2006 at 8:31 pm
    For question 1- If your not going to online, just using what you have now for a master, then use Nattress Standards conversion, works great.
    If your going to online convert your files first, either with Standards Conversion or have a transfer house do it. From my own miserable experience if you use the footage as PAL in an NTSC timeline when you go to up rez your timecode will be off and your clips will be captured wrong. I found out the hard way.
    Question 2 you have to go into the motion tab and change the distort field, I’m not sure of the numbers off hand.
