Activity Forums Apple Final Cut Pro Legacy NTSC + PAL footage in same project
  • NTSC + PAL footage in same project
    Posted by Rap on October 9, 2006 at 11:24 pm
    hello
    i have 2 questions
    what do i do if i have footage that is PAL (I’m working on NTSC project)
    2- i have digitized and edited footage that was shot anamorphic and now after finished editing i print t to tape i don’t get the 16:9 mask i get a stretched picture . what do i do ?
    Rap replied 19 years, 11 months ago 2 Members · 3 Replies
  • Rap
    October 12, 2006 at 6:29 pm
    wow i didnt know this is such a hard question !!!!!
  • Enzo Tedeschi
    October 12, 2006 at 10:02 pm
    You will need to convert your PAL stuff to NTSC. You will need something like along these lines:
    https://www.nattress.com/Products/standardsconversion/standardsconversion.htm
    There’s a bunch out there – perhaps someone else on the forum can recommend some good ones. I don’t use standards conversion much myself, but I have been happy with the stuff I have purchased from Nattress in the past.
    As for your 16×9 footage… The stretch is actually the “correct” way of getting 16×9 to tape. The anamorphic stretch is corrected upon playback to the correct aspect ratio. If you want to letterbox your image when putting it down to tape, you can make a new sequence which is 4×3, and then drop your 16×9 cut into that sequence – FCP will automatically arc the cut and letterbox it. Put that down to tape.
    Enzo Tedeschi
    ____________________________
    Editor
    http://www.outpostpps.com
    Sydney, Australia
    Check out our latest music video – http://www.outpostpps.com/thebleed/
    Check out the Outpost PPS Video Podcast launching October 29 – http://www.outpostpps.com/podcast/
  • Rap
    October 15, 2006 at 9:37 am
    hey Enzo thanks for your reply
    i made a new sequence not anamorphic and dragged my master sequence into that new one but nothing changed. am i missing anything?
