Activity › Forums › Adobe After Effects › NTSC Motion Graphics to PAL
  • NTSC Motion Graphics to PAL
    Posted by Joe Harrison on January 20, 2008 at 6:44 am
    My problem is this..
    I have just completed a very complex 15 second intro for a video all in motion graphics using After Effects at 30FPS.. Lots of camera and graphics movement cut to a music track..
    and now I need it in PAl 25 FPS..
    Does anyone know a fast solution for me to render this out in PAL .. my fear is that I will mess with all the timing doing a 25fps export.
    Any suggestion would be truly appreciated..
    Joe Harrison replied 18 years, 8 months ago 2 Members · 2 Replies
  • Darby Edelen
    January 20, 2008 at 7:25 pm
    Try creating a PAL composition and dropping your NTSC composition into it, then use Layer > Transform > Fit to Width to resize the NTSC footage.
    If there are video elements in your NTSC comp then their frames may be blended, but if it’s all animated/motion graphic elements then they will be re-timed in the PAL comp to have the same duration as they did in the NTSC comp.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Joe Harrison
    January 21, 2008 at 4:44 am
    Worked great.. would never of thought this could be so easy..
    Thanks so much
