Activity Forums Apple Final Cut Pro Legacy NTSC Monitoring on Macbook Pro
  • NTSC Monitoring on Macbook Pro
    Posted by Michael Nichols on May 10, 2008 at 12:18 am
    I have a macbook pro w/ a caldigit 1.5TB drive going into the SATA port on the express card slot. I have a groovy NTSC monitor that I would love to use to monitor my uncompressed 10-bit files in Final Cut Pro. Echo Bridge is not an option, right?? What sort of firewire device can I use STRICTLY for monitoring? Something cost effective. The AJA IO HD would be nice, but I cannot afford that at the moment and my projects are still SD!
    Rennie Klymyk replied 18 years, 4 months ago 8 Members · 12 Replies
  • 12 Replies
  • Shane Ross
    May 10, 2008 at 12:59 am
    Laptop? Options are limited. Matrox MXO is your cheapest option for uncompressed. Then the AJA I/O line. And that’s it.
    If this was DV you can use camcorders and the like, but uncompressed takes a third party card.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Aaron Neitz
    May 10, 2008 at 1:25 am
    Shane’s dead on. Personally AJA’s products are second to none and will work until the end of time.
  • Michael Nichols
    May 10, 2008 at 2:34 am
    I hate the idea of dropping ANY money on a device that is limited to SD. I think I might save the pennies and just get an IO HD.
  • Shane Ross
    May 10, 2008 at 2:58 am
    The MXO does HD…but it is OUTPUT only…so…
    Shane
    http://www.LFHD.net
    Read my blog!
  • Ed Dooley
    May 10, 2008 at 1:05 pm
    But the MXO2, scheduled to ship in July (we’ll see) does I/O in digital and analog HD and SD, all for $1,500. One notable thing it doesn’t do (that the IOHD does) is hardware assisted convertion to ProRes.
    Ed
    https://www.matrox.com/video/en/products/mxo2/
    [Shane Ross] “he MXO does HD…but it is OUTPUT only…so…
  • Chris Poisson
    May 10, 2008 at 3:07 pm
    Michael,
    I have an old JVC DV deck with a broken tape mechanism which I use as a pass through to my Sony PVM monitor with my MacBook system. I feed FireWire to the deck and component out to the monitor. It plays even 8 bit timelines in real time, go figure. You might be able to pick up an old deck like this cheap on eBay.
    Have a wonderful day.
  • Michael Nichols
    May 10, 2008 at 4:55 pm
    I have a JVC HDV clamshell. I wonder if I can FireWire out to that and component out to the monitor.
    Wouldn’t it just use the DV CODEC though?
  • Bob Roberts
    May 10, 2008 at 10:06 pm
    re: IO…Look for used. I found one on eBay for $650!!!
  • Sean Oneil
    May 11, 2008 at 1:56 am
    [Shane Ross] “Matrox MXO is your cheapest option for uncompressed. Then the AJA I/O line. And that’s it. “
    A third option is the Magma external PCIe enclosure.
    Sean
  • Shane Ross
    May 11, 2008 at 2:48 am
    [Michael Nichols] “I have a JVC HDV clamshell. I wonder if I can FireWire out to that and component out to the monitor.
    Wouldn’t it just use the DV CODEC though?”
    Well, I am sure that FCP 6 does to the DV downconvert via firewire….but it isn’t as good of quality of normal DV footage, much less for any use to judge quality. Reference only, unless you get a third part card.
    Shane
    http://www.LFHD.net
    Read my blog!
